just got my 1jz vvti
Ok guys I just received my auto 1jz vvti rear sump out of a soarer. Just like how it looked in the pics. Got the whole motor and trans for 1300 and 245 shipping. What you guys think? Had it shipped to the shop where I work and just got it to my house today. I'll have pics up tomorrow.
USB cable is far too thin. You need legitimate wire. You need to extend the camshaft and crankshaft sensors. If you are OBD-II you can use the wire from your current crank shaft sensor. The knock sensors are also shielded. I prefer to simply replace the two in the GTE harness with the two in the GE harness.
11213-88400 for non vvti
11213-88410 for vvti
so they are "different"
and thus i would order the ones for the car properly.
i just order my parts from toyota in australia.. if i cant get them from here.
part numbers are still different.
11213-88410 VVTI 1jz intake
11214-88410 VVTI 1jz exhaust
11213-46020 VVTI 2jz intake
11214-46011 VVTI 2jz exhaust
Some people use the non vvti 2j gaskets on the non vvti 1jz but have the following problem:
the difference is that the 2j's are molded a little different in that they follow a path that gooes around some of the valve cover bolts, making them just a little longer
so they have to push in the gasket a bit here and there to make it fit..
im going to assume the vvti is no different in terms of its small differences.
