swap help!!!!!!!!
swap help!!!!!!!!
what up fellas. thanks for having the time to read this. well my baby is a 93 sc300 and im planning on doing a heart transplant. most likly the donor will be a 2jz-gte. this swap is thee real deal for me. im planning of getting the parts first then the motor. this is where you guys come in, i need a list of ALL the parts i will require for this swap. and i mean all the parts. i would apreciate it alot if you guys can help me out with this swap.
by the way, if i dont get the 2jz and decide getting a 1jz motor. is it the same parts that i will have to replace if i end up getting the 1jz?
Welcome to CL, please use your SEARCH or look in the STICKY. See attached links...scroll down, you should be able to find what you're looking for somewhere in all that GOODNESS...good luck
https://www.clublexus.com/forums/sc-...d-threads.html
