SC- 1st Gen (1992-2000)
Sc400 lack of horse power!
Old 09-15-11, 12:28 PM
maser832
maser832's Avatar
Default Sc400 lack of horse power!
My lexus is running sluggish..no horse power ..smells like gas real bad. Even when I put the pedal to the metal..it hardly moves..i ckecked my cat converters and they were red hot ,so I gutted them out.also changed my spark plugs,fuel filter,and air flow meter.and still the same..any ideas or help?
Old 09-15-11, 01:09 PM
Dv8
Dv8's Avatar
Replaced o2 sensors?
Old 09-15-11, 01:17 PM
maser832
maser832's Avatar
No havent replaced 02 sensors...not getting a check engine light
Old 09-15-11, 03:19 PM
ls400love
ls400love's Avatar
Fuel pump ecu and o2 sensors....try resetting the ECU by disconnecting the cable that goes to the negative side of your battery and see how she runs and wait to see if any codes pop up
Old 09-15-11, 05:53 PM
maser832
maser832's Avatar
I reset it the computer and still no difference ...took it for a spin and still no CEL's
Old 09-15-11, 06:00 PM
xxtoobsxx
xxtoobsxx's Avatar
seafoam, new plugs and then o2 sensors. Also check your timing, could have jumped a tooth or when your last water pump was installed coulda been off a tooth.
Old 09-15-11, 06:29 PM
maser832
maser832's Avatar
I doubt... it jumped a tooth
Old 09-15-11, 06:48 PM
hovsc400
hovsc400's Avatar
so the timing jumped a tooth...i was gonna tell you to unplug the airflow meter and drive it and see how it performs
Old 09-15-11, 06:57 PM
JustChill
JustChill's Avatar
listen to toobs when he sys the timing may have jumped it tooth. It can happen and has. He knows because it happened to him. ECU could be fried or maybe you have bad coil packs.
Old 09-15-11, 10:34 PM
CrispyST3
CrispyST3's Avatar
Maybe you are getting too much fuel for the amount of air coming into your cylinders. When that happens the air/fuel mixture has too much fuel for the amount of air coming in, and then it doesn't ignite as much so you're not getting a good power stroke on your pistons and then when it comes back up for the exhaust stroke it's slower, causing your whole exhaust event to be weak.
Old 09-15-11, 11:05 PM
V8drummer
V8drummer's Avatar
Is it idling really rough too? Could be one of your coils.
Old 09-15-11, 11:31 PM
xxtoobsxx
xxtoobsxx's Avatar
Lindy lives...might need your help on my r154 and single turbo install soon!
Old 09-16-11, 04:33 AM
maser832
maser832's Avatar
It dosent really idile real bad..but im starting to think it could b a bad coil.pack or bad ecu..
Old 09-16-11, 04:36 AM
maser832
maser832's Avatar
When I unplugg maf sensor it does not do any difference..except the idle picks up a bit..
Old 09-16-11, 07:31 PM
Joey-E
Joey-E's Avatar
Check your ignition coils.
Quick Reply: Sc400 lack of horse power!
