how come my sc does not have drls in the high beams
Well my 98 SC does not have drls or city lights in them why is that and some other sc's have them
Did you import a 98 model to Canada? You can do "makeshift" DRL's by putting something dark (ie. Duct tape) over your light sensor for the automatic headlights. I passed with that.
the drl makes the high beam 9005 bulb run at a lower power so its not as bright. the smd/led bulbs dont turn on at the lower power and only turn on when you push the lever back/forward to turn the high beam on (higher power). the drawback is that your highbeam isnt as bright as the normal 9005 bulbs, but the 68+ led/smd bulbs are still bright enough for when you need them.
boostinsc
SC- 1st Gen (1992-2000)
03-06-12 02:10 AM
Lexson
08-23-02 03:25 AM
