92 SC4 Ignition wire order
Brand new wire set. Really improved performance. Had to take them out for some additional work. I put everything back together, but soon there were problems. I suspected the wires, and sure enough I forgot to secure one of them in its clip. When I tightened the cover, it pinched that one wire, so she didn't idle so well. I called Autozone about my warranty and only wanted the one damaged one replaced (I had to lie about what happened because it was obviously my own fault that the wire was damaged). Unfortunately, they said they couldn't replace just the one. I had to bring in the whole set. They kindly replaced it with an identical brand new boxed set. So now I have the wire set I need but no diagram to refer to. I know, I should have used masking tape or something to copy the assembly pattern of the ignition wires, but I was foolish. I searched for this information diligently, but couldn't find it.
Will someone please provide me with a diagram of the positions of the ignition wires for my 1992 SC400, a photograph of the properly installed wires, a drawing, or written instructions. I could follow written instructions quite well if they're detailed enough.
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
Linked from FourWheelPerformance.com:
![](http://www.fourwheelperformance.com/1uz_tacoma/tacoma_1uzswap_93.jpg)
You should be ashamed of yourself. If you broke it, you should pay for a new set. I know -- they're a big company, it won't make a difference, etc, etc. We all pay for it in the end because they have to price things just for occasions like this.
EastWind
04-03-07 08:21 PM
