Door Speakers Not Working Please Help
I have been searching for this but don't see any threads on it.
My speakers are not working but my sub is fine. Anyone ever have this problem? Is it the amp and where is it located? Is it a fuse and where is it located? It was working fine all morning until I drove it home from work. Thank you. -JJ
1JZ Single SC400
Are you saying all the speakers are not working or just the door? Chances are the speakers are prolly dry rotted and quit or the factory amp is bad. Do you have a NAK or Pioneer system? The amp is in the trunk by the spare tire.. The known problems is that factory amp gets wet or moisture in there are fries it. Check the amp for rust or any signs of moisture.
ok here we go... ur amp is in the trunk on the right hand side under ur cd changer. if it was working fine at one point then ur amp probably got messed up. if ur speaker are bad or cracked theybshould still make noise. if it sounded fine and now it sounds bad its ur speakers. if the sound just stopped working then its ur amp.
another thing u can check is ur fuse. its located it the drivers side kick panel next to where ur left foot would be behind the rug. the fuse ur gunna look for i believe is a 7.5 and its somewhere towards the middle of the fuses. it should say something like brake light fuse. check it and even if it "looks" fine change it. or check it with a multimeter.
Its just the door speakers. I dont know if its NAK or pioneer. While on the way to work this morning I hit a bump and all the speakers turned right back on lol. Then hit another bump they all turned off again, very annoying. It keeps doing this now. Could it be some connection with the amp? The recent service I got done was new back tires and alignment so doubt that had anything to do with it but it was working fine until then. Thanks everyone for the replies.
jintei
02-04-11 12:53 AM
