No sound from stereo
Hope someone can help me out. I took my 92 SC400 through a car wash today (for the first time since I've owned it ) and now there is no sound from the stereo. The antenna works fine as does the display on the unit. I've tried the CD as well- no sound. Any thoughts. Could it have been the wash or just a coincidence??
It's time to remove the trunk lining, by the Cd unit and locate the amp under the Cd. Use a flash light to see if there is any water around the amp, if you see any remove the amp and let it dry. Locate the drain tube and see for any leaking/clogging before replacing the amp, if the amp is still working after it has dried.
Radio display comes on - shows radio stations , changes to cd and tape but no sound whatsoever- I'll check out the amp. Thanks Boys - I'll let u know
You guys called it- sure enough I had water around the Amp. I took out the Cd player but didn't take out the amp (didn't really know how) Anyhow cleaned up the water, used a blow drier around the amp and wires for a few minutes and, boom, music. THANKS AGAIN - I guess you Ranger fans are Ok.
I love hockey...would have loved to played (professionally) in the NHL, if only I had been born in Canada as an infant because it's a law that infant's must learn to ice skate before they are one.
I found a tube lying beside the amp. - it appeared to attached to a metal tube coming from the area of the gas fill up door. I reattached it there - is that what your talking about or is there another one??
Lexicon1
02-14-09 08:36 PM
APU6speed
03-24-05 02:07 PM
