Fan Clutch: Fix or GO Electric
My fan clutch just went out and I'm considering just throwing a electric fan setup on it. Curious as to what all of your experience is on the sc300 with them.
I would fix the clutch fan, the factory clutch fan and shroud will flow a lot more efficiently than an aftermarket e fan setup. Although E-Fans will clear up a lot of room in the engine bay and make the engine bay look a lot neater, i'd stick with the clutch fan still.
If it's not the IS300 fan setup I wouldn't choose to run it. On extended hard runs and on some dyno's other e fan setups do overheat.
Ill keep my stock fan clutch setup
Is there a way to test and see if the stock fan clutch is still strong?
I had a nightmare scenario a few years ago. My fan clutch burned out on an older 90's Mercedes E-Class that I owned. The car overheated and I blew the head gasket. I'd prefer to not have that happen again obviously lol.
A few days ago someone mentioned spinning it in a certain direction and see if it feels tighter during a full rotation. I tried spinning it in both directions, and it seems to spin freely to me. There is a little resistance but it's not stopping or anything.
You have to trim a little bit on the side of the shroud to fit in the SC maybe a 1/4 ", i had mine for the longest i will pick it up from the shop tomorrow since i am getting the brackets made so it' fits the SC or Supra radiator PNP.
I think i paid $250 + for mine , I will let the EMS control mine so it will work just like the GS300 .It uses the same fan setup as the IS300 my GS has 240k that shows how reliable the fans are!
