SC- 1st Gen (1992-2000)
Stereo has no power.
Old 09-25-11 | 12:35 PM
JJ823's Avatar
JJ823
Default Stereo has no power.
My deck has no power going to it, just completely shut off last night. Cant turn it back on does anyone know what it could be? Could it be the amp?
Old 09-25-11 | 01:32 PM
6SOARER's Avatar
6SOARER
Need More info, is it the stock deck or aftermarket stereo.
First and obvious things I would check fist is the fuse and all your connections.
Old 09-25-11 | 02:47 PM
JJ823's Avatar
JJ823
Its a aftermarket alpine deck. Ok thank you.
Old 09-25-11 | 03:50 PM
Luxor's Avatar
Luxor
The first thing to check is all fuses related to the stereo.
Old 09-25-11 | 04:43 PM
JJ823's Avatar
JJ823
just found it ....here for anyone who doesnt know http://wiki.answers.com/Q/Where_are_...92_Lexus_SC300
Answer
There is one black plastic fuse box located under the hood which mainly houses the relays. As you open the hood, it is on the driver's side about 2/3rds of the way down the engine compartment located far right against the fender. Non-descript 9"x5" approx. with two plastic head screws you can loosen by screwdriver or even with a quarter to lift lid and access various fuses and relays. Legend for fuse / relay applications should be imprinted on the underside of the lid; also built into the lid is a fuse holder, you may have some spares there if you're lucky. The other is under the dash on the driver side where your left foot goes. There is a panel that kind of curves downward you need to remove to expose fuse panel.
Read more: http://wiki.answers.com/Q/Where_are_...#ixzz1Z0lU0iXn
http://www.justanswer.com/lexus/1g8h...us-sc300.html\
hello, and thanks for choosing just answer, you have #1 radio fuse in junction block 2 under hood left frt fender near the center # XXXXX you have radio fuse # XXXXX in jucntion block 1 under drivers side dash area left of brake pedal. you should see the fuse block. #6 7.5 amp fuse. hope this helps . if you accept agreement and need further assistance i will be glad to help. thanks, Jeffrey
Read more: Where is the radio fuse on a 1992 Lexus sc300 - JustAnswer http://www.justanswer.com/lexus/1g8h...#ixzz1Z0lHl6KV
Joegbr
06-14-17 08:54 PM
renegad44
ES - 6th Gen (2013-2018)
19
09-02-14 06:48 AM
jdsethi
12-23-12 01:07 PM
epikeddie
03-10-12 07:16 PM
floridaken
33
08-24-10 02:04 AM
Quick Reply: Stereo has no power.
