need some 1jz help
So here's the deal long story short, I bought a 1jz for my 92 sc300 but I didn't see the engine tell after i bought it. I sent my friend over to go cheak it out and he said go for it. This is coming for a guy that only knows how to work mustangs. Well the intake is pulled completely apart and the harness is cut up. And its missing odd and end sensers. Idk were to find info on it or a book something to help me along.
I bought a 1jz harness a few years back if I remember correctly it was $700+ for a good one, then you must have it extended and mod it. So good luck with that side of it.
as far a tsrm and other stuff
try this its almost every file I have on the 1jz
http://www.filedropper.com/1jzall
+1 on a unfinish project for sure, intake, harness, front sump change, replace mis parts thats going to be alot....Damn man GLWB...
I hope you didnt spend more than 600 for that....try and source out parts here and supra forums and all esle fails you can go to the dealer and get the manual for the 1jz
P.S. I would change friends
I ended up with one of those before. Best bet i would say for you to do if i was your friend ( not a mustang guy) is try to save up for maybe a 1.5jz, your motor i think if from a chaser (front sump) and looking at it from the turbo pipes its more of a 90degree rather than a Y pipe. crack it open to see if anything is wrong. To you sir i say good luck, to finding better friends, motor will be fine.
sell that thing man and buy a proper one from a reputable importer.
Youve got alot of work and money to get that into running shape and then you still dont know the condition internally.
You made a mistake here no big deal you live and learn, abandon ship while u still can.
