What would look better Poke fitment or Flush?
Ive just got in my varr 2.2.1 im running 18/10.5/+0 offset and thinking of running a 245/35 tire all the way around and in dropped 2.5 inch on coils.. but i wanna know what looks better on our cars the poke look or the flush fitment ive seen alot of the flush fitments but very few poke fits so if you or you have pictures of the two fitments it would be greatly appreciated.
thanks again
thanks again
Honestly, it's your car so you should do whatever the hell you want. No one should care about your personal offset except for you. I've seen high offsets with meaty tires that look killer. I've seen negative offsets that look plain stupid. Just install what's practical to your lifestyle. If you're planning on driving 20k+ miles a year with super negative offset wheels, you're gonna break or wear some costly suspension parts down the road.
those are deff gonna poke either if you drop or not.... get to rolling! try to get as close to 2 degrees camber all around... i think they will look good i like a little bit of poke out of stock fenders
It depends, do you want traction? Do you value normal tread wear? You can easily fit a 295+ on a 10.5" tire with the correct offsets. Or you can stretch a tiny set of 245s on them and run a lot of negative camber. It all boils down to what you want: traction and tire life, or.....something else.
Depends on the person, its your car so what do you think looks best. Personally I run a stretched tire (225/40 on a 10" wide) and have the car slammed so that the fender lip is just about touching the lip of the wheel, so pretty much no poke but very low. Some cars have a lot of poke and have nice pulled fenders and look good too, just depends on the wheels and your tastes.
