How To Remove Front Bumper of 93 Sc300
hey guys im new to the sc lifestyle and i want to add a new coat of black spray to my oem sc400 bumper guard, so i have to take the bumper off to get a clean, even coat
any pictures for help, how-tos??
even step-by-step will help ALOT
Hello and welcome to club Lexus! Try this out to give you an idea. http://www.lextreme.com. Just look up tutorial for how to remove sc front bumper.. Good luck
take off the plastic cover underneath the bumper covering your undercarriage,
unbolt the bolts along the top of the bumper which connect it to the headlight assembly,
on each side there are bolts that attach the bumper to the headlight assembly/fender, to get to these take off the fender lining on that side you dont have to remove all of it, and simply unbolt i belieave 2 or 1 bolt on either side.
where the bumper has holes/grill area for air look up and underneath you will see metal supports clipped in all the way around it,
you dont have to take off your headlights but it might be easier for you if you remove them,
unplug the side markers and fog/cornering lights aswell. be carefull not breaking the clips in the bumper grill area as they are a biotch and a half.
btw i had a front mount intercooler so in yours there is probably a couple more bolts than mine, and there should be a ambient temp sensor hanging off the inside of the bumper just unclip that
Someone did a write up on this in Club Lexus ---> https://www.clublexus.com/forums/sc-...ar-bumper.html
americk22
SC- 1st Gen (1992-2000)
07-15-10 07:25 PM
