Replaced climate control module still nothing
Got another SC...ha im addicted now. ANYWHO i was told the climate control module was out so i purchased a used one from a fellow CL'er which is gurenteed to work and the seller has good feedback so i wasnt worried about a faulty item. However plugged it in...still nothing. Any other ideas? im not to sure where to look into this, checked the fuses...they where good. Checked the ones in the fuse box. are there others? anyone else ever have this problem? Thanks everyone! ur fellow SC noob.
Bo, double check the switch above the radio controls? When I was diagnosing that the engine was bad (before I installed the new one), I'm sure that the old climate control system fired up fine. Has to be something stupid, cause I never messed with it during the install.
Hope you're enjoying the car.
i know the auto climate button in the back the plastic is cracked around the rear case, all wires are connected, checked that. checked the fuse in the fuse box. what engine are you talking about?
Before I changed engines, I dug into the old one to see exactly what was wrong. While checking compression on that, I was inside the car cranking it over. Old engine was junk, so thats why I decided to replace it with a good low mileage one. I remember the climate control lighting up.
Hope you figure it out.
Check your fuse for the cigaret lighter.. its in the kick panel on the driver side.. the climate control and cigaret lighter run off the same fuse. Mine would light up but none of the buttons worked. After I replaced that fuse it started working
wouldnt tht make the cig lighter not work as well? it works, only way i made it to this god forbidden **** town of gurnee
yes checked that when replacing the module. there was nothing in it, the cig lighter works perfect, charges my gps. no coins in there. Thank you
