Odyssey pc680 battery installed in sc400!
I looked into the pc680 and just not sure it would cut it since its lacking 200 cold cranking amps compared to a recommended battery. Think the next step up would do the trick just right? I think its a 960 cold cranking amp battery.
i might ever see -1f but even at that most people driving a high boost rwd car are garaging it during the winter....
i mean if your having issues with cranking over a sports car in the dead of winter you might look in to a spp2150.... http://www.sonicelectronix.com/item_...r-SPP2150.html
![Wild](https://www.clublexus.com/forums/images/smilies/wild.gif)
(i think 1000+ cca should do the trick hahahahaha)
the odyssey pc680 isn't for motor vehicle use.. on there website it says for atv, snowmobiles, motorcycle..... 680amp for 5seconds that's not good,, and you CCA (cold cranking amp) is super LOW, @220amp wonder what are you going to crank?... these batteries don't meet standards.
using an odyssey battery isn't consider an upgrade its a downgrade,
do research, and go to odyssey's website... you just fitted a motorcycle battery on to you car
It's been almost a year and never had failed to start or gave any issue plus I added a 600 Watt amp so I can just say it works great for me as it starts my hi comp v-8 with no problem but although it has enough amps to start the car just fine it has little capacity so if you run the radio with the car not running then it may fail you but I love it!
