Question on Fog Lights.
I have tried and used the search feature but i could not find what i was looking for, my question is i have a 93 Lexus sc300, with the 97+ front end conversion. I have bought the fog light housing, but i do not have the wires needed? Anyone have any idea where i can find the harness needed to turn on the fog lights? ![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
Thanks,
Sam
Thanks,
Sam
Try searching harder next time...
So here's a freebie to the part you're likely going to need since I'm feeling generous...
'97-'00 OEM foglight connectors PN: 90980-11156
I found it all here...
https://www.clublexus.com/forums/sc-...ou-do-now.html
92-94 SC's do not come with fog lights; they come with cornering lights.
Here's a link to one of the great DIY/tutorials that are stickied up top on this forum.
(Next time, you'll know where to look)
https://www.clublexus.com/forums/sc-...onversion.html
Toyota/Lexus actually does have the wiring you want in their warehouses but the problem is that you have to know the exact part number for whichever electrodes they are. No one knows what those part numbers are, just the numbers for the rear connectors.
I had your same issue and what I ended up doing was stealing the thickest gauge prong/wires from my car's Lexus Phone system that I had removed. There were dozens of spare wires and I just found the ones that matched closely enough.
It isn't clearly stated how to get the wires on the forums until this thread.
The GM plug idea sounds interesting but I'd just try to preserve the factory rear connectors. Also, definitely use a relay system if you have a 92-94 SC. The writeup from O.L.T. is basically the same way you would create a foglight harness for any car, only he points out certain wire colorations to use that are specific to our cars.
