SC- 1st Gen (1992-2000)
Aftermarket under engine cover
Old 01-02-12, 08:15 AM
Track5tar
Track5tar's Avatar
definetly a waste of money...
Old 01-02-12, 09:23 AM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
Smile
Originally Posted by KingPhilip
Finally I found the guy!
http://www.ebay.com/itm/S5-Splash-Sh...ht_2792wt_1348
Looks like he disappears whenever he sells this product. So, for future reference, his username in eBay is; trenshaw19. Quite pricey actually, $299.50. Although it comes with new mounting hardware, the air shroud and the engine undercover. I'll contact him when I have time to ask what's the difference with the OEM ones. And oh yeah, he's also the same guy that makes and sells the BFI!!!
I know that eBay seller. He is a friend of mine. He sells good stuff.
Old 01-02-12, 09:30 AM
Luxor
Luxor's Avatar
For $300, it better be made out of aluminum!
Old 01-02-12, 09:39 AM
OG Dada
OG Dada's Avatar
Originally Posted by cww180
Can stock replacements not be ordered?
You can, I checked it last night. For the engine under cover alone that's $150+, and then for the air shroud $50+, then you gotta add the mounting hardware and what not, so around $230+. And that's all with the Sewell Lexus discount we're getting.
I was thinking the same thing! Too bad my SC didn't come with the engine undercover, though I'm planning on creating a skid plate, I still need an undercover to mock up the right locations for the screws. It's part of my preparation for going low on static.
Old 01-02-12, 10:24 AM
scENFORCER
scENFORCER's Avatar
Ya my SC defiantly needs a new one as well, but $300+shipping is way too steep..
Old 01-02-12, 11:00 AM
DJVe
DJVe's Avatar
just curious if anyone knows, but if one switches to another front bumper whether it be t&e, origin, autocouture, etc..., does the stock under cover even work anymore? and if not would this one work?
Old 01-02-12, 11:35 AM
Photon440
Photon440's Avatar
It's $225, the rest is shipping. No, it isn't aluminum. He starts with a stock Toyota part but modifies it so that you don't have to unbolt it each time to access the oil filter. Instead, finger locks allow you to open an access panel. New bolts and clips come with it. I'm planning to keep my car awhile, so I'm thinking of getting it. Each oil change would make it seem worthwhile.
Old 01-02-12, 11:42 AM
scENFORCER
scENFORCER's Avatar
^ Let me know if you do get it. I'd be interested in checking it out..
Old 01-02-12, 03:12 PM
OG Dada
OG Dada's Avatar
Sorry, but I don't see what's with all the trouble of removing it whenever it's oil change time? It's not like you do this every week. JMO.
Old 01-02-12, 05:37 PM
TougeSC3
TougeSC3's Avatar
Tom Renshaw. Find him on Facebook.
Old 01-02-12, 06:07 PM
BeansIS
BeansIS's Avatar
Seems like you could make that with $5 worth of fiberglass
Old 01-02-12, 09:39 PM
BigManne
BigManne's Avatar
or a sheet of abs plastic
Old 01-03-12, 03:37 PM
horent135
horent135's Avatar
I met in person too, great guy and helps out alot. I know he a member on here, but his stuff is overpriced tho. But who cares, ppl still buy it from him.
Old 06-20-13, 05:02 AM
TheHoboMan
TheHoboMan's Avatar
Originally Posted by VC455
I believe that it comes for both the 300 and the 400. It replaces the plastic cover that goes from the bottom of the front bumper back to the front crossmember. The reason I want one is that it has a door to allow access to the oil filter and it isn't supposed to sag like the factory unit.
I am able to access the oil filter on my SC300 with the stock front splash shield on...
Old 06-20-13, 07:24 AM
Midengtoy
Midengtoy's Avatar
I wanted to make one of my own out of ABS plastic but the hard part is cutting all the slots and vents correctly to still keep the engine bay cool. Remember these vents just don't make things look clean they are designed specifically to cool down the car too because our SC's don't have a front grille.
Quick Reply: Aftermarket under engine cover
