Finally got my free-air sub
Chicago Lexus Club Moderator
Originally posted by AVRsc4dub
any of u guys actually have pics or can post pics of how to make a board to mount the aftermarket sub to fit in our stock deck board?i had a jl 10 free air and i tried to fit it but i cant really figure out a way to make it look clean
Chris
AVRsc4dub, good pt. Tell u the truth, I have no idea what that spacer's suppose 2 look or function. DIrEctQL, thanks for trying to get the pix for us.
It's time like this that I feel like a lazy chump for not being a paid member.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
wow thats looks really clean!!but 1 question did u remove the rear deck cover to show us how its done or do u really need to remove the rear deck cover.i really dont want peeps to see that if i was to park on the street..
Yeah the rear dash mat goes back over all this stuff. The stock sub grill is held in with clips that lock into the stock free-air. Witout that stock baffle, you'll have to get creative with presentation, either by cleaning up the opening in the dash mat or by figuring a way to use that grill again.
Well, today I have purchased a 6' by 6' 1/2" carpet padding/cusion material at Menards. It's almost identical to the one Lexus uses. Also purchased this foam tape. I will use both of them to secure the rear deck and also insulate because you guys should know that dynamat is not exacly the only thing out there that would work well.
Chris
PS. Will post pictures of this project.
Chris
Originally posted by lex400sc
Here's what our long-lost friend Dub did for his sister's SC...
DIrEctQL, one problem with the foam is that it's better at stopping road/wind noise and the such than it is at stopping vibration noises. Dynamat increases the weight of panels which helps keeps vibrations at bay. I'm not sure which noise you're trying to stop, but it's just stuff to keep in mind
Yeah, dynamat is basically tar with lead in it. It very dense and very good and dampening vibration. In home theater, we use sandbags and leadshot. Carpet is good for absorbing reflective sound such as the higher frequencies, but has minimal effect at dampening low octaves.
Dub, nice to see you still lurking around
. How's your sister's SC doing?
i installed my kicker free air sub,and it looks completely stock in it's position on the rear deck. the cover for the sub still fits and it sound really clean.
The bass is deeper than stock,but i do have an alpine 5 channel amp installed as well. i used the original plastic /metal ring that housed the old sub,cut that ring,shaved it down to make the kicker sub fit perfectly in it's place and used screws to afix the sub to the ring-when finished,mounts right where it used to -in stock form. will post pics soon..........
NEXTLEVELCOUPE please post pics soon..i really want to see how it is!the bad thing is that i dont have the stock subwoofer ring no more :.( hopefully i can find one or if u know someone sellin one that would be great!
So I finally did it. Check out the link below. Just to let you know you guys were wrong about the carpet padding not being a good way to sound proof. Sounds even better except something in the passager door is still vibrating!
https://www.clublexus.com/forums/sho...119#post415119
Wow that sounds like what I need to do to my car, I really wish I just did my install myself, I don't trust anyone w/ my car anymore, only person that will do it yourway is yourself. Anyways, do you have directions on how to get the seat out, I tried to grab the bottom of my seats and maybe I didn't pull very hard, but I couldn't get them out. This is a thread that illustrates it well, do I just yank harder???
https://www.clublexus.com/forums/sho...t=seat+removal
Phoenix, pull up on the seat like you're pulling seat cushions out of a couch. Due to the cramped space and awkward position you'll be in, you might have to put your weight into it. Lean forward and yank.
tuterz
09-13-09 12:04 PM
