HID foglights???
damn foglight done burned out,... is there an HID foglamp replacement conversion kit out there for H3's.... I'm thinkin' HID lowbeams is next and was wonderin' if the same was out there for the fogs.
what tha hell was involved in that job?? you got any pic's of how you did that?? Do people's eyes just burn up instantly when lookin' at your car from incoming traffic?? (assuming you HID's up top too)
I have a 2001+ BMW 5 series Projector, bulb, ballast and everything in my low beam that i just got done last saturday.
and while i was there i was bored and had an extra pair of 9006 HID's that use to be in my low beam so i didn't have any use for them so i put them in my fog light. The only HID kit you can use in the fog light is the type with 2 wires coming out the back of the HID bulb which the mucculluch kit has. all i did was take a dremel and make the square hole in the middle of the fog light housing bigger and rounder. then i took the dremel and file down the 3 legs on the 9006 HID bulb so its perfectly round. then i just insert the buib in and it was a perfect fit. i used the stock H3 Hinge thing to hold the 9006 bulb in place and it holds it perfectly. there is a bit of glare but thats going to be fixed soon. i am going to try something over the weekend and i'll see how it goes.oh yeah also you have to bend the glare guard up a little by using a screw driver to push it up or opening up the housing and removing the glare guard like i did.
