What's the secret on removing driver side window regulator?
Swapping out driver side window regulator for new one and ran into problem.
Can not seem to remove the 2 screws on top of regulator that holds window .
In searched and found DIY and said there are 2 14mm bolts but mine doesn't have bolts.
This on a 99 sc400. My friends 98 sc300 is also like mine, no bolts.
It looks like a flat disk that screws onto a bolt. It has l4 littles holes similar to your chrome antenna on the body of the car.
Any help would be greatly appreciated.
- tried a search on yahoo, nothing
- search on CL but only found 2 DIY but mention there's 2 bolts to be removed( mine look like 2 disk about 1in in diameter.
Tried need nose to twist , but too tight.
- mine are not even rusted or even look tampered with
Thanks
Thanks
Keeper of the light
You can see exactly what you are saying in the DIY you said you read: https://www.clublexus.com/forums/901715-post25.html
Oconee1985
Performance & Maintenance
05-25-13 09:55 AM
