First things to invest into SC?
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
Hey CL, I'm new here as you can probably tell but I tend to linger around and read posts from time to time (creeper I know
) But I have a question and I hope to get a good answer from you guys.
I'm buying a 99' SC300 this weekend (well, hopefully) and I'd like to know what I should invest into it first (example. Intake, coilovers, rims, etc.) ..I've asked a few friends but I get mixed answers, so I'd rather ask you guys. And uhm, my budget at the moment is 2K and the car is going to be a daily (if it means anything)
Thanks in advance![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Edit: I guess I forgot to mention that I will get the car maintenanced first! The 2k go into the car after I make sure she is running like brand new
Thanks in advance
Oh yeah, I should have mentioned invest AFTER taking it in for maintenance. But thanks for the answer, do you recommend a certain brand of coilovers?
Maintenance maintenance maintenance!
Depending on now many miles the car has, that could use up most of your $2k. Things I suggest looking at are; bushings, timing belt, transmission mount, water pump, and anything else thats a common wear part. Get the car running like new, then modding will be much easier!
Check all fluids, especially the coolant system. Make sure your clutch fan is in good order. If it fails you are going to blow a head gasket and have serious issues. Check out the condition of your power steering fluid. If it's not cherry red, flush that. Check your brake fluid. If it's black, bleed them. Of course check your oil level/condition as well. Remove timing belt cover and inspect belt. How many miles does your car have? Inspect your serp belt as well. Check the condition of your main ground cable connections and look for any corrosion. If there is any corrosion, disconnect each point and sand these areas. Check out your throttle body and see if there is any major carbon buildup in that area including the IACV. Check the exhaust for any leaks. Check the condition of your control arm bushings, sway bar bushings, rack bushings, steering bushings, etc. and replace if necessary. Replace the air filter if needed.
After the normal maintenance items are completed, I would look into new brakes and tires. Brakes help you stop, tires keep you on the road. After that it's fun and games from there. Good luck, post some pics if you purchase it.
@scENFORCER
Sorry, sorry! I fixed my post, haha. So AFTER, maintenance, maintenance, maintenance! What should I do? Coilovers? Intake? I need more suggestions!
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
After the normal maintenance items are completely, I would look into new brakes and tires. Brakes help you stop, tires keep you on the road. After that it's fun and games from there. Good luck, post some pics if you purchase it.
As for coilovers. I got BCR coilovers. My friends say good things about it and on this forum. So I went a head and bought them. Never look back. If not, Megan coilovers are good as well. Check out the vendor site they got some good deals.
@Josh400: Oh, a friend told me about Megan coils, I'm guessing they must be worth it then ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
@Kohinoor: Thanks
Hopefully she'll be mine soon enough!
@AlphaMotor: Haha, thanks!
I appreciate all the replies guys!
@Kohinoor: Thanks
