Need more light!!!!
i was thinking of changing my driving headlight bulbs with my high beam ones.
has any one got hassled for this???? wont it be noticable especially if the cop ask to see me turn on my high beams which will be as bright as my low beam.
any suggestions????
I need more light to illuminate the highway.
peace
any suggestions????
peace
What kind of bulbs are you using? OEM Koitos? Try using Philips Vision Plus or Sylvania SilverStar in 9005/HB3 size, and hack them to fit in the 9006/HB4 socket. They will be bright enough for driving purposes. Otherwise you'd have to convert over to HIDs.
Cops won't be able to tell or hassle you about it. I'm 99.999998% sure about that because almost no cops have any clue about lighting and lighting laws that subtle. I drove around for six months with 9005 bulbs in my low beams and no problems whatsoever.
The 9006 to 9005 conversion is amazing. You will honestly see a difference at night. Your wiring harness will not melt either, beauce its only another 10w.
Go for it!
Go for it!
one of the things that **** me off is people driving with their high beams on. You guys are telling me that you purposely do this? =X
Hopefully the way the projector is set, it wouldn't be as annoying than the actual high beams, but if not ......
Please reconsider doing this as it is unsafe for other drivers on the road.
I've had high beams in the low beam bulbs for ages. Never got pulled over (just for that...) but when i do get pulled over, they dont look twice at the lights.
The high beams in the low beam projector doesnt blind the other drivers as the beam is pointed too low whereas high beams are meant to point "high" ie.. that's why it blinds people.
Do it and shave the middle tab from the light and put them in. They give a good lighting improvement.
hope this helps: https://www.clublexus.com/forums/sho...threadid=17907
I think I used the soldering iron to melt the part
