hating my headlights everyday a lil more
Ok so im having serious thought of beating my headlights to pieces when i picked up my soarer the headlights really sucked yellow & toasted id drive with my high beams and couldnt see 5 ft. ahead so i came acorss O.L.T`s DYI which i thought was awesome on cleaning your headlights so i did that opened them bad boys up they actually had dirt in them as in sand and twigs pieces so i take my headlights apart clean buff my projector lens sanded and clearcoated my covers with uv protective clear coat and installed sum 3000k hids got excited till i turnt them on...... do the headlights normally illuminate so bad??? i noticed inside right behind the projector lens has some plastic tabs myb restricting any suggestions or opinions to better em ?
hahaa fellow dominicano lol.............. so Are the tsx projectors the best way to go any advice on the install? and how do you guys feel about having hids in the cornerlights or too much?
ive had 3000k yellows for low beams on my other cars and never had that issue they actually are stronger than the 6k whites and see better in the rain myb cuz they dnt use projectors but in this case opposite im goin try 6000k ive got laying around if not i try the higher wattage if not ima retrofit the poop out of these headlights
lexus4jess
02-21-06 02:14 PM
