Fogs and AC not functioning
So I replaced my tail light because the tail light sensor went on from inside the dash, after i replaced the bulb, i reset the battery and now my fogs do not turn on and my air functions are not working, but the air function screen is turn on but there's nothing showing. Also the temperature screen isn't showing anything but its turned on.
Much help appreciated!
Did you check the fuse?
If you pop your head underneath the driver side dash, you will see the fuse panel. The one you are looking for is up and right from where all the fuses are. If you have the cover it will help you located were they are. You kind of have to go looking.
Let me see if I can find a pic...
See the first pic, look at top right and you'll see the hidden fuses
https://www.clublexus.com/forums/sc-...ght-relay.html
