Door not opening.Yes I searched...
So my passenger door will NOT open.. It does not work from the inside nor the outside. I have taken off the inner door molding and exposed the door actuator. The little tab that the cable pulls on to release the door moves but will NOT open. I have searched, and every thread/post has been about the clips/cables etc. i just want to get my door open so I can swap out the actuator. The tab on the top moves all the way back as if it is ready to open yet it will not. Is the door stuck in the lock position? If so, how on earth do I "unlock" it? The key from outside the door wont realease it nor will the door locks on the inside. Any help would be awesome!
ok the problem can b that the door lock mechanisum is messed up or jam in 2 instances #1 look to c if the rod coming out of white clear plastic box on insidde of door is connected to the hole in the door handle that controls opeing and closing frm outside, if it is then yes the door lock mech is messed up or jamed if it isnt u can put it in even if clip is broken or lift it up or push it dwn, if the cabel from the door lock broke off that then ur in a bad spot cause the cable 4 the door hande comes off door lock mech it just has a ball on end and pulls a lever, 1 time i had it all connected smae thing but the alligmnet on door was off so the wieght of the door was on the stricker of the door so i lifted the door up as i was pulling handle and pulling up on doo and wala open sesame, if, even if cable if door lock cable broke put window in up postion and remove croos memeber bar that has 3 screw holding it to door to give u more room and visabilty and u should b able to manuley w/a flat screw driver move it and open ur door. hope this helps i deal w/this porblem alot so im very familiar w/door and locking sysytem not a expert but ive done a few and have succesfully open them all
Lubeboy
SC- 1st Gen (1992-2000)
05-30-17 12:52 AM
tonyzebra
15
08-22-12 04:40 PM
