SC- 1st Gen (1992-2000)
Carbon Fiber Interior Trim
Old 12-23-11, 01:05 PM
  #31
Cranbery
Cranbery's Avatar
Originally Posted by xxtoobsxx
Ill make one on my next pieces!!
Looking forward to it!
Originally Posted by BeansIS
I have not read the full tutorial but seems good. The only important parts I will add-
Before laying the carbon on the Panel be sure the panel is black. Since you are only doing 1 layer of carbon. If the weave shifts and your panel is red. You will see it.
Second thing, again before laying your carbon, put some epoxy to and let it dry to tack. By doing so, it will be much easier getting the fiber to stick once u get it down.trust me it makes 100% difference.
Good luck, there are also plenty of "laminating" tutorials on YouTube.
Thank you good sir.
  #32
xxtoobsxx
xxtoobsxx's Avatar
I use 3m heavy duty spray glue! The epoxy methode is too time consuming!
Old 12-23-11, 06:43 PM
  #33
LEX_MAN
LEX_MAN's Avatar
Originally Posted by scguy
i can probley make those pieces 4 u n real carbon fiber 4 a few hundred$ i usally charge about 100$ a piece depending on size and difficulty if u wnt to go with the real stuff not that cheap vynal that in my opion looks like *** but if u like it then its ur car
Hmmm... thats sounds cheap. So you're doing real CF overlay and charge $100 ? I'm thinking you are using clear part a/b epoxy ,and sanding everything and polishing?
Thats cheap .
Old 10-08-12, 09:42 AM
  #34
jeffreyjje
jeffreyjje's Avatar
are you still doing the real carbon fiber interior trims? - jeff
kazuto88
05-29-19 02:13 PM
Randre19
Chicago Lexus Club
10-02-14 10:30 PM
PYSpeed.com
Club Lexus Vendor Marketplace
24
07-25-13 04:10 PM
Chachiiis
18
04-25-12 04:29 PM
Quick Reply: Carbon Fiber Interior Trim
