what are cars with projectors smaller than SC's, pre 1997 models only.
I could search and research this alone but i figure id rather post and see your thoughts before while i work on another project.
- smaller in any degree is good.
- pre 1997 model cars only because of cost
- hopefully we get some commonly available options! lmk thougths fellas
opps can you post this in the right forums
The HID-equipped Mark VIII did not use a projector anyway; they were regular reflector lenses in both the rare 1995-96 offering and the 97+ redesigned lights.
The OP didn't say HID projectors, but then again, projector lenses were kind of rare in the 90s anyway. The 3000GT/Stealth offered them in 1994+ models.
Without knowing the final goal, we won't really know what vehicles might do the trick.
keep the ideas coming guys!
Things narrow considerably when you want a projector high beam. I don't recall any other car of that vintage having projectors for everything.
My former Stealth: TT (12.5@109 with mbc, downpipe, injectors)
![](https://moojohn.com/stealth/lightson.jpg)
I assume you already know you can buy plug & play projector highs on ebay for around $100 that match the stockers nicely, with either a chrome or black interior surface..
Why pe-97 only?
With the few bucks you'd save buying old projectors, you are really not doing anything to improve light output or obtain a nice cutoff.
Odds are, any projector made that long ago is probably a POS. Just get some TSX projectors, they are not expensive and will be a million times nicer than anything pre-97.
^ because its just for aesthetics. I'm more interested in how its going to look with the lights off rather than on. I rarely use my high beams anyways! TSX's projectors are much too large also i think. I'll have to look into it
Ok before i continue, I was searching around to see if its been done and... hmm i cant tell if this is a retrofit or if these are just delined black housing high beams. lmk thoughts people (eliteskills car btw)
![](http://i112.photobucket.com/albums/n167/azn_rider/Photoshoot/STI_1474-Edit-2.jpg)
my main problem is I have black housing lowbeams with a bright projector reflection... then the contrast from my high beams (which are also blacked out....well I didnt paint the shield) takes away from how well it should flow together
OP should consider Bi-Xenon projectors such as FX-R's or Morimoto Mini's to retain high beam function. But if it's just for sake of having projectors in the high beams, why not buy the eBay set? It'll save time, money, and headache.
But IMO, light output is also part of aesthetics (Morimoto Mini output photo):
![](http://i22.photobucket.com/albums/b302/driftermomo/Club%20Lexus%20related%20pics/MorimotoHIDl.jpg)
Nice light output with sharp cutoff makes the car appear more modern and up to date. If you're going to open up the light housing to retrofit, why not put in a good pair of projectors while you're in there?
