Lexus SC/Toyota Soarer 19inch rim thread.
#151
Thanks Zerodrag, I should have considered MK4 Supra lowering springs. Sc3/400 specific springs run really conservative drops.
Anyone running 19×10 F and 19×12 R with lower offsets, roll and pull, PBM coilovers?
#153
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
You would need a big pull in the real. I ran 19x10 +10 and 19x11 +13 and couldn't slam the car without a massive pull in the rear and a crazy tire stretch. My fenders are shaved in the rear and rolled in the front. The front was fine since I was running 225/35/19 tires.
#154
Thanks for the info KiraX, I will probably stick to no more than 11 in the rear then.
#155
12's are doable in a higher offset, and at 12" wide you'll have plenty of lip even on a high offset wheel.
#156
Yeah, I see that would have been the case. I only asked because wheelflip has some good choices from time to time and I wanted legit wheels with a healthy lip, especially on the rears. Not trying to do overfenders unless it's the full BN Sports Blister aero.
Jrodas21 (02-12-21)
#160
The following 4 users liked this post by Mannyyacht:
