SC- 1st Gen (1992-2000)
I'm going to try CLR on the driving lights
Old 12-31-11, 11:42 AM
  #31
sc-driver
sc-driver's Avatar
Originally Posted by O. L. T.
Gotta pull the fender liner completely if you don't pull the headlights, then they are still a PITA to reach and remove. If you do pull them you have to partially pull the fender liner, pull the headlights, THEN pull the driving lights. pain in the *** either way.
I've owned a 96 sc400 since 2006 and I've taken the foglights and headlights out so much it's a piece of cake now. there are 3 methods to take out those fogs:
Method 1:
Pull back the fender liner, remove the 2 10mm bolts holding the headlight, remove the top 10mm bolt. Take out the headlight. Reach down and remove the 2 bolts behind the foglight and 1 screw on top. Pull the foglight and done.
Method 2:
Remove enough plastic from the underside of the car to reach the bolts and screw. Then pull out.
Method 3:
If you have skinny hands and arms, you can reach through the large opening next to the foglight. Remove the bolts and screws and pull out. Not easy if you have big hands
I've done all 3 and I it takes maybe 5 mins max for each now.
I've done the CLR route/rubbing alcohol/polish and gotten ok results. Take a good look at the fog lights. The entire inside is not that shiny reflective material. That stuff is only near the bulb, if you look closer to the outside lens, you will see it is ordinary plastic just like the surrounding material.
I got sick of trying to make it look clean so i painted the plastic black and kept the reflective material.
Here it is when I bought it. The fogs looked disgusting and one of them had a build up of water and green *****t:
This was the best I ever got them, with all the work I did:
I said f-it and painted the plastic black:
Old 12-31-11, 12:08 PM
  #32
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Koo. Not for me though, like them not to stand out too much.
Dumped the CLR and waiting on them to dry, they look better already. will know how much soon.
Old 12-31-11, 12:29 PM
  #33
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Well even before they dry you can see a big difference so for me it was worth using it. Look at the earlier pics and the brown and then these and while it can't make it a brand new light it can dramatically help discoloration.
Old 12-31-11, 12:41 PM
  #34
sc-driver
sc-driver's Avatar
More power to you if you get the results you wanted. If it's just debris you're trying to get out, clr alcohol and even water works. But if you're trying to remove nasty build up on the inside, you will have to open them up for that.
One thing I do recommend that got them a little cleaner was using rubbing alcohol diluted with a tiny bit of water (pour it in and shake it!) and then using a hair dryer on LOW setting to dry them.
The reason I painted the inside plastic black was because the plain bland-looking plastic stood out too much when I looked at the front. The black makes it stand out less (at least to me) since it matches with the center black grill and those slits next the fogs.
Old 12-31-11, 02:18 PM
  #35
O. L. T.
Keeper of the light
O. L. T.'s Avatar
I think the effort made a difference, and I didn't do much of anything - just pour it in, so I'd say the CLR helps a little.
BEFORE AND AFTER
Old 12-31-11, 04:12 PM
  #36
nlc
nlc's Avatar
seeing what u jus went thru umm i think imma jus save for a 97-00 front. lol i kno those fogs are easier to deal with.
Old 12-31-11, 09:10 PM
  #37
lexfrmtex
lexfrmtex's Avatar
That made a huge difference.
Old 12-31-11, 09:46 PM
  #38
MooJohn
MooJohn's Avatar
I think the difference is worth it for a quick slosh-n-pour. Too bad I don't have fogs.
I think I'll chop up my turning lights to make them into trim for some Blazer-style projector fogs.
Old 12-31-11, 10:11 PM
  #39
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Bingo, Jed's a millionaire. Will still buy new fogs down the road because all my other lights are brand new and no cleaning will make them as crystal clear, but the difference between doo doo brown and acceptable is worth my pour.
Old 12-31-11, 10:18 PM
  #40
greens14
greens14's Avatar
^ why dont you just bake them open and clean them also? or are pre97s not baked open
Old 01-04-12, 02:59 PM
  #41
megamax
megamax's Avatar
i vote to take apart the lights and paint them. they look better than the after on olt's troubles(dont hit me).
Old 01-04-12, 03:05 PM
  #42
O. L. T.
Keeper of the light
O. L. T.'s Avatar
None of that is going to restore the plastic fully so too much effort and really doesn't have anything to do with clr so I'll stick to the method here.
Old 01-04-12, 06:21 PM
  #43
CalitriSC
CalitriSC's Avatar
much better than before.
Old 01-07-12, 06:45 AM
  #44
B1TEM3
B1TEM3's Avatar
not an eye sore anymore
Old 01-07-12, 10:11 AM
  #45
stockhatch
stockhatch's Avatar
It does look much better. Well worth the effort IMO. Too bad you can't get them in glass.
Quick Reply: I'm going to try CLR on the driving lights
