No heat but AC is fine
Hi all,
My heater is not working for some reason. I noticed it last winter ( I live in Florida). My AC is fine and cold. Any suggestions? I turn on the heater when the engine is warmed up and no heat. "Winter" is approaching!!
thanks much
Rob
thanks much
Rob
early
The early cars had a mchanically actuated hot water flow valve located on the top center of the firewall just behind the engine. It was operated by the mixing vane (blend door) servomotor via a push/pull cable through the firewall. Check to make sure the cable hasn't slipped off and that it is driving the valve full open in max heat position. Or in summertime fully closed in max cool.
Re: early
Can you just replace the VSV or do you have to replace the whole thing.
BTW, for those who are wondering, its the little assembly that has two heater hoses leading into the firewall.
chnk
SC- 1st Gen (1992-2000)
17
11-20-11 11:20 PM
