Battery light
In case your problem hasn't been solved, I had similar issues in my older SC. My car kept dying when I was below 1k rpm, regardless if I fully charged the battery.
Turns out the PS pump was leaking fluid and the alternator is located directly under it, causing the alternator to go bad. I had the PS pump sealed up and got a new alternator and didn't have problems after that. My friend told me after the fact that if that is the case, the alternator can just be cleaned using brake fluid cleaner and a replacement is not necessary.
Andymi
SC- 1st Gen (1992-2000)
11-25-01 02:29 PM
