Creaky Squeeky Doors
Help....What can I safely put on my Hinges?...I have 92 400 SC Love it but doors creak really loud when opening and closing......any ideas out there?
Thank you
MItch in NJ
Thank you
MItch in NJ
1JZ Single SC400
If it is popping, remove the 10mm bolt that the hinge allows to swing. It does not do anything to the support of the door. It is a well known problem. Do this on both doors. If this doesnt fix, spray some wd40... GL
WD-40 Did the Trick...Thanks all!!!!.........Next...the Steel is showing though in big spot on one of my side pillars......should I remove them and let the steel shine through...or cover them in the Carbon Tape stuff???
Thanks
Mitch
Thanks
Mitch
