SC- 1st Gen (1992-2000)
High Miles SC400
Old 02-01-12, 11:27 AM
mrmaggot
mrmaggot's Avatar
Originally Posted by TARMAC
R154 did come from MK3 TURBO supras, and also 1JZGTE cars.
Important... Which is cheaper LOL
When I search car-part for 95 supra NA trans I only got 2 and they were expensive....
Old 02-01-12, 04:36 PM
RotaSpinna
RotaSpinna's Avatar
MK3 and early MK4 W58s sit in about the same position once bolted in. The 95+ MK4 W58 sits a little further back.
The MK3 being older will be cheapest. Check your local craigslist listings and junk yards.
Old 02-01-12, 05:14 PM
Bertman
Bertman's Avatar
I definitely agree with everyone's view that the 1UZFE can go well beyond 200k with proper service. I bought mine about a month ago with 250k and she runs very strong & smooth for a engine with such high mileage. I changed the oil over to Mobil 1 5w30 and she's not leaking any oil which is such a huge plus in my book! I also checked my oil level today and she's still at the full mark. My advice to you is to ensure that the Automatic tranny is in good shape and not leaking. Same goes for the Power Steering Pump. Mine is leaking and I do have a 1-2 late shift issue when cold, possibly due to a bad valve body. But I do intend to replace the tranny whenever possible. I also did replace Power Steering hoses since they were indeed leaking a little bit. But overall, I say you can't go wrong with it!
Old 02-01-12, 05:15 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
https://www.clublexus.com/forums/sc-...e-sc-ever.html
Old 02-01-12, 05:26 PM
LunaVyohr
LunaVyohr's Avatar
While you CAN use a MK3 W58, it will be require a lot of custom work. In the end, the cheaper price isn't worth the headache of trying to make it work.
Old 02-01-12, 06:32 PM
mrmaggot
mrmaggot's Avatar
So it has to be a 95+ w58?
What about the R154?
Old 02-01-12, 10:57 PM
Bertman
Bertman's Avatar
From what I've seen so far, the W58 has more aftermarket support for a SC400 Swap. I may be wrong about this, but I don't think anyone actually manufactures an adapter plate for the R154 Tranny. Quantum Auto sells a W58 Swap kit for the SC400.
However, if in the future you plan on making huge amounts of power, then I would definitely consider the R154 Tranny. It's far superior than the W58 in high power output applications. Just be ready to fabricate more custom parts, such as an adapter plate.
Check out this thread for more info regarding both swaps. (The thread is more for the SC300 Swap, but it gets you near the ballpark figure)
https://www.clublexus.com/forums/per...-a-thread.html
Old 02-02-12, 12:03 AM
TARMAC
TARMAC's Avatar
any sc300 w58 is the cheapest/easiest way to go.. the problem with the mk3 w58's is the shifter location.. a w58 from a sc300 puts it in the correct location.. or a w55 from an is300
Old 02-02-12, 01:12 AM
-Samurai-
-Samurai-'s Avatar
Still burns rubber at 200,200!
Old 02-02-12, 05:19 AM
mrmaggot
mrmaggot's Avatar
Sounds Good guys
Guy is supposed to come put a down payment on my s-chassis cars friday, hopefully he will come through.
Old 02-02-12, 07:12 AM
Kalogerus
Kalogerus's Avatar
There is a saying "1UZ is bullet proof" which is true.
Originally Posted by iridebmx
unless you are me who doesnt fix an oil leak and check for oil out of laziness =( the 1uz will run well past 200k
O-oh.... good thing you reminded me about them valve cover gaskets lol
Old 02-02-12, 10:41 AM
LunaVyohr
LunaVyohr's Avatar
If you use a MK3 W58, you would need a custom driveshaft, a possible shifter extension, custom cross-member/mount, and a mechanical to electronic speedometer conversion.
I'm unsure about the R154. You'd have to message some SC400 people here who have done the R154 conversion. You could also go on Lextreme and search.
Aluminum flywheel adapter kit.
Steel flywheel adapter kit.
A little research goes a long ways, guys.
pinoiryder
10-15-15 08:04 AM
coolexus96
25
05-06-14 10:49 AM
sparkyguy
12-01-13 07:09 AM
96sc400
14
02-18-04 02:15 PM
Phierce
11-03-01 09:52 PM
Quick Reply: High Miles SC400
