SC- 1st Gen (1992-2000)
Cheap Climate control LCD fix, Steps/Pictures!!!!
Old 01-31-12, 06:13 PM
2jzforlife
2jzforlife's Avatar
@O.L.T. This soldering job should last me a good time:
O. L. T.
Keeper of the light
O. L. T.'s Avatar
You're showing me pics of the original solder bro, I know toyota flux.... but to be straight with ya, you're camera is calling your bluff. That pic is the pic you took before you desoldered it (IMG_3191) and the one you took after you desoldered it above is (IMG_3194). Put back together is (IMG_3195).
Good try though........
Each side has a connection to each side of the mobo. I've seen people only solder one side and the screen half function, that's why it's important. I'm glad yours is working, and it looks good.
It's nice to get a blackened screen out and a nice fresh one in. I think that is one of the biggest eye sores of the SC's.
Old 01-31-12, 06:15 PM
2jzforlife
2jzforlife's Avatar
@WadeLovell Sorry man i dont know the part number, but if you call up your lexus dealer they can look it up for you
Old 01-31-12, 06:19 PM
2jzforlife
2jzforlife's Avatar
@O. L. T. Ye man i had to be playing the guessing game all the time at what temp is set and where its blowing at. Feels better than burned out one Plus i dont like the backlight of the lcd- theres 3 regular small bulbs installed and im thinking about soldering some led's in there since my speedo is white and everything else is also white
Old 10-02-12, 06:45 AM
bryan767
bryan767's Avatar
doing this today.
I think as long as your thorough, I dont see how this could be that hard. Plus if you have a desoldering bulb and maybe an extra hand to hold the screen in place, it shouldnt take to long.
I also believe the best plan of attach is to snip off the old screen before desoldering so you dont have to desolder the entire unit at once, you can go prong by prong. Either way will work, i think this would make for a cleaner desolder though.
Old 10-02-12, 07:17 AM
1WILLY1
1WILLY1's Avatar
looks good man but this is not a DIY i would attempt , good job
Old 10-02-12, 07:45 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I bought my LCD over three years ago off of Ebay and it cost 125 shipped to the door. I sent mine off to OLT and he soldered it for me for a measly 40 bucks. I couldn't be so much happier now with the screen being lit and no black anywhere on it.
You did a great job, at the time I decided to something, I thought it was more to it than what I just read on here. Again it looks good and glad it worked out for you.
Old 10-02-12, 08:09 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
I will have to do this to my broken one. I was lazy and just bought a used one that worked. Thanks for the DIY!
Old 10-02-12, 09:46 AM
Ali SC3
Ali SC3's Avatar
Originally Posted by bryan767
doing this today.
thats a good idea with the snipping off the old screen and removing one at a time, will make life much easier. half the battle is in having your soldering iron at the right temperature. most common mistake is not getting the iron hot enough and it becomes very difficult and gives poor connections.
Old 10-02-12, 04:32 PM
bryan767
bryan767's Avatar
Pretty simple if you have a desoldering iron or a suction bulb. A second person helps a lot so they can hold the board while you get the remaining solder out. I used my method of cutting the pins then desoldering each one. Works a lot better. I held onto one side with a pair of dykes.
Desoldered!
Backside
Resoldered!
Look how dead this screen was :/
All done. Took about a hour to do. In all honesty, unless you literally know what micro solder is, and implys. I personally wouldn't attempt it yourself. I bought a 15/30watt soldering iron new from RadioShack, that had the finest tip I could find. This wil help you get into the whole of the board to get the heat further down.
jonas's RX
SC430 Classifieds
09-19-17 05:48 PM
CRybicki15
08-04-17 04:17 PM
gilfix1
16
03-03-10 06:19 PM
Quick Reply: Cheap Climate control LCD fix, Steps/Pictures!!!!
