SC- 1st Gen (1992-2000)
Cheap Climate control LCD fix, Steps/Pictures!!!!
Old 01-30-12, 10:40 PM
2jzforlife
2jzforlife's Avatar
Default Cheap Climate control LCD fix, Steps/Pictures!!!!
Hey guys i got my new lcd screen for my climate control today and decided to take some step by step pictures. I got it from ebay for 47 bucks and is much better than sending it in for a rebuild for over 150 bucks. It toke about a good 45min- an hour to complete everything. Gotta have soldering skills like me =)
Heres the new screw before it went it
There is total of 6 small philips screws on the outside to get the climate control opened
then you will need to unplug two connectors
heres the old screen before i de-soldered it
de-soldered it from the other side
thats where the old screen used to sit
my old one was quite burned up
Now all i had to do was repeat the process and solder in my new lcd
and here it is, works great
Old 01-30-12, 10:47 PM
yausito
yausito's Avatar
nice work !! I am gonna do the samething soon ! ...
Old 01-30-12, 11:31 PM
poorsupra
poorsupra's Avatar
great diy! this topic hasnt been well documented like this. considering these are 45$ on ebay this is a great cheap diy to fix that eye sore of a climate control every sc has.
Old 01-30-12, 11:59 PM
RaynArt
RaynArt's Avatar
oh you need soldering skills?
lol.
nice work, maybe ill have a friend of mine help me out on this
Old 01-31-12, 01:33 AM
CalitriSC
CalitriSC's Avatar
Thanks for posting this. I need to do this too, nice cheap fix. Is there an ebay link?
Old 01-31-12, 02:29 AM
CrazySC300
CrazySC300's Avatar
I have a spare LCD screen myself...I'm tempted to do this (Since my screen is starting to go bad) but I have no confidence in my soldering skills.
Old 01-31-12, 02:56 AM
chashiubow
chashiubow's Avatar
Nice work, thanks for sharing.
I remembered my climate control was fixed for $75.00, parts and labor included. Didn't trust my own de-/soldering skills...
Old 01-31-12, 07:44 AM
Tabaka
Tabaka's Avatar
Luckily I don't have any LCD issues as of yet (144k miles). I however have decent soldering skills and I could probably tackle this if needed. Thanks for the pictures and DIY notes.
Old 01-31-12, 10:39 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
$150? Wow somebody is getting reamed. $40 labor tops somewhere, if you pay more than that you get hosed and trust me for $40 you don't wanna desolder those pins yourself without a lot of experience because there are a bunch and they will cold solder and certain areas of the LCD won't work correctly (so be careful if you do try this).
The DIY for this is in the ice blue thread from 2003 and one from last year I did as well, but you did a nice job on your lcd. I love the fact these screens are only $45 since the problem is so common.
Here's a better look inside from last year https://www.clublexus.com/forums/sc-...lcd-today.html
and from 2003 https://www.clublexus.com/forums/693010-post357.html
The thing I was saying about the cold solder joints was if you look how the holes are not filled completely in here:
Versus here:
Those connections that are not completely done will cause the LCD to wig out from cold solder connections and you'll be back in it doing it all again, so just be careful when you do it because it's a real PITA to have to re-do it all over again and that's why I say it's almost not worth it to DIY when the fix is only $40. Still not to discourage, if you have the ability and can do a really nice solder there's no reason not to.
Old 01-31-12, 10:44 AM
2jzforlife
2jzforlife's Avatar
Yup thanks guys for the feedback, and the soldering was quite simple since there is a good amount of space between each contact. heres the link for the lcd screen where i bought mine http://www.ebay.com/itm/300654733298...#ht_2353wt_952
but this isnt the only place you can buy them i came across multiple other sites before i bought mine
Old 01-31-12, 10:52 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
if you look in the first link I gave you'll see this post: https://www.clublexus.com/forums/5550858-post17.html
That guy says the sellers name is gtshokoor that sells the better (thicker) LCD screens that look a lot more heavy duty and seem to light up cleaner. I'd recommend those LCD's since I've worked with them all. By contrast the other ones are thin and light up a weird off color.
Old 01-31-12, 11:04 AM
ASTERiSK
ASTERiSK's Avatar
Looks great man, I need to get this done myself. I had to figure out the climate control settings by memory instead of seeing the icons on the screen :|
Old 01-31-12, 11:14 AM
WadeLovell
WadeLovell's Avatar
What are the dimensions? Any part number or manufacturer information associated with the replacement part?
Old 01-31-12, 06:04 PM
2jzforlife
2jzforlife's Avatar
Thanks, my connections on the other side is soldered in fully, they dont wiggle at all. Heres a pic when i hooked it up to test and so far i love it =)
Old 01-31-12, 06:11 PM
2jzforlife
2jzforlife's Avatar
@O. L. T. look right here there is no way this will wiggle out of place. This pretty secure:
Quick Reply: Cheap Climate control LCD fix, Steps/Pictures!!!!
