Stock Sub replacement?
Hi guys,
In my last SC i had I put a 12' JL in the trunk and mounted the memphis amp I had under the rear dash where the stock sub was(saved space for the after market amp). This Time around I was thinking about just going with a 10' and swaping out the old sub for a new one. I Know there is not alot off room for a deep 10' sub so I assume I will need to go with a shallow mount for it to fit in the clearence space. Any info on a replacement I can use that will fit in where the stock sub is now? I dont think I will need such a big amp as I had before (memphisPR2.100) I was thinking about placeing a new amp where the stock system amp is but I know the one lexus gives is vary small. I know someone on here has done this before.. If all else fails I can always go back and do what I did in my old SC but I would like to have the sub mounted on the rear dash this time insted of having a sub in the trunk like last time. Thanks guys!
Hi guys,
There ya go bud i dont know if that was exactly what you were looking for man hope i helped
Xeeeeeem
13
02-17-06 07:22 PM
saelee39
12-30-05 12:37 AM
