SC- 1st Gen (1992-2000)
Okay... I guess it's my turn...
Old 12-04-12, 06:37 AM
  #76
BAD954BOI
BAD954BOI's Avatar
So when is the tune date?
Old 12-06-12, 07:29 PM
  #77
Specaiist
Specaiist's Avatar
As soon as I install that built transmission, I'll be back on the dyno. I'll definitely keep this thread updated.
Old 12-06-12, 07:31 PM
  #78
Specaiist
Specaiist's Avatar
Originally Posted by JJSSC300
hey man, nice SC. I'm planning a similar build with mine. just wondering which built auto are you going with?
Automatic Transmission Factory (ATF) in Davie. The tranny that I plan on installing is good for 900hp (proven).
Thanks by the way,
Old 12-07-12, 07:18 AM
  #79
jwin
jwin's Avatar
Nice build. after seeing your TT intake manifold fitting on the ge head makes me not even wanna bother with getting a TT head.
Old 12-07-12, 08:21 AM
  #80
Cleet
Cleet's Avatar
I'm interested in what exactly it took to make that intake manifold fit. I have a custom fabbed ffim but this has me reconsidering.
Old 12-09-12, 07:13 PM
  #81
Specaiist
Specaiist's Avatar
To be honest.... Being that I wanted to stay automatic and keep my drive-ability
as close to stock as possible, It was best that I went with this factory setup. I originally had the XS Power manifold and the q45 throttle body. But it made no sense to use them. That setup wouldn't give me anymore power than the factory GTE VVT-I manifold and throttle body. The GE and GTE head are the same...
If you know how to weld or if you know a good welder, this is a easy custom job.. You'll need your GE lower runner and a GTE lower runner. All you'll have to do is remove the to portion of the GE runner and replace it (re-weld) with the top portion of the GTE runner.. You will have to re tap a few holes. But once you get it started, it'll all fall into place..
Old 07-01-13, 08:57 PM
  #82
BAD954BOI
BAD954BOI's Avatar
So what exactly is the update?
Old 07-02-13, 06:44 PM
  #83
Specaiist
Specaiist's Avatar
So the car runs solid. However, I made a miscalculation with the setup. The turbo is just too big. It's out of my power range. My car is still auto. And I'm running a uni-chip piggyback. As a result, my car is essentially "stock" for all intents and purposes. So my rpm's are still stock. The car shifts at 6200 which is way to soon for this turbo. If I had a 5/6 speed and had the ability to rev out to 7500, then this turbo would be ideal.
So I'm now looking for a PT6062 or better yet, a PT6262. That should compliment my setup much better....
Old 07-06-13, 05:51 PM
  #84
DoomLight
DoomLight's Avatar
there is a shop here called Hi-Boost. he's used that S366 on a lot of cars and it makes crazy power. i think the lowest powered car is 457whp on a 1jz. a few of them hit 700+ with that turbo.
i dont think you should go down to a 6262 yet. that 67 still have life left in it. but thats just my opinion.
if you were running a manual. you'd feel that bad boy breathe thats for sure.
Old 07-07-13, 02:20 PM
  #85
Biddles
Biddles's Avatar
car looks seriously good man
supraclay
Performance & Maintenance
01-08-12 09:26 PM
GGPIS3
Southeast
07-14-10 10:08 PM
Sc dRifta
CL of Southern California
05-06-07 04:34 PM
97-SC300
10-24-06 07:25 PM
Quick Reply: Okay... I guess it's my turn...
