Help I bought a 93 sc300 hood doesn't line up with fenders ..
Do you guys know how to realign a hood.It's not matching up with the fenders.
Also the wheel on the passenger side is flushed with the fender but the driver side wheel is "sunk inside the fender"...What can that be? There's no front end damage.
i agree with enforcer sounds like possible front end damage that was poorly repaired, especially if they were rolling on cut springs .. springs are one of the cheapest investments mod wise . id try tweaking the bolts on the hood hinges see if that could help a little??
The fact that the previous owner cut the springs on the car is not good news. Hopefully that's not the only thing jimmy rigged on the SC.
I replaced a fender on my sc a year or two ago and had the same problem, I loosened up the bolts on the top of the fender and wiggled it into a tight fit and tightened them back down looks great now, no gap. The fact that it had cut springs worries me that some of the guys might be right. could be something scary lurking in the dark
Most of the time when you replace a bumper, fender, hood or anything body wise your going to have some alignment issues. If you say there is no front end damage, then I guess there is none. Just take it step by step by aligning your hood and fenders first since they are oem still. Once you get that done adjust your bumper, just remember it will never be perfect like oem. Replace those cut springs as soon as you can, its not good on your suspension.
when was the last time you had it aligned?
if "sunk in" is like 1/2 inch than it might have to do with the alignment
read on another forum about that being a problem due to bad alignment, not sure how to be honest though
good luck
good luck
jaysauce
11-03-12 05:12 PM
khanhdom
07-20-11 03:03 PM
