SC- 1st Gen (1992-2000)
IS300 Steering Wheel W/ Working Cruise in my SC3
Old 02-20-12, 11:38 AM
scoobySC3
scoobySC3's Avatar
Default IS300 Steering Wheel W/ Working Cruise in my SC3
So I finally got time to mess around with the IS300 factory cruise control, I think I figured out how to get the cruise function to work, but not 100% sure that all the functions are there, like the accelerate function, but still need to test it out on the freeway. I did confirm the Cruise function it self to work however! Here is how I did it.
Uninstall your factory airbag and wheel, take mandatory pictures next to the new wheel to show it off.
Once you confirm your new steering wheel is way more awesome than your stocker, get your soldering iron, solder and tools and get to work on the cruise control.
This is the stock IS3 Cruise/Shift button harness:
-Use a small flat head screwdriver, or knife and carefully pop the retaining clip up so we can de-pin the harness plug.
Remove all pins from the plug except for the ground for the horn(large blue wire on the far right)
-I used a small cotter pin to de-pin the plug as I could not find my dental picks. Make sure you insert it straight in, on top of the pin so it will lift up the small plastic tab holding the pin in the plug. Then pull the wires out of the plug.
Once you have all the pins out, you will want to find the white/black wire coming out of the cruise control, and you can see it goes directly over to the left side shift buttons. We will cut this wire so we can route it directly to the plug.
I borrowed some pins and wires from the OEM phone harness(you will need both of them)
Use one of the borrowed pin&wire and solder it to the white/black wire on the IS3 harness, and plug it into the plug in the location below, I also plugged in the red/black wire in the location below as well. *Note - I shrink wrapped my horn ground wire to protect it, as it had been slightly burned previously.
Next we need to pull back the loom from the IS3 cruise control harness to locate where the solid black wire merges with the red/back wire.
Be careful not to break the wires off the back of the cruise control module like I did, if you do, just carefully solder it back on.
Now we will need to find the junction where the solid black wire connects with the red/black wire. Carefully snip the black wire at the junction. *Ignore the green wire in this picture, it is from the factory phone harness and will be soldered to the black wire and connected to the main plug.
Like so:
Should look like this when it is all done.
Re-install everything, hook up the air bag, and enjoy your new steering wheel!
So all in all, there are only a few steps.
-Cut white/black wire going from cruise to the shift buttons, solder on a pin and plug it in.
-Remove the solid Black wire from the Red/black wire, solder a new pin to the solid back wire and plug it in.
-Plug in red/back wire, with the solid black wire removed from it.
-Make sure your cruise control works!
I do apologize for the mostly ****ty write-up as I did this all in a span of 2 weeks and did not take detailed pictures of everything along the way. Again, I did confirm the cruise itself to work perfectly, but I need to test if all the other functions work. I might have to break out the multi-meter again and test the IS3 cruise vs the stock cruise module and what voltages they put out when the functions are used. I noticed that when you turn it on for example, voltage will drop to .02, and when you push it up, it will fall to 8ish volts, and when you push it down, maybe 5volts, but I cant remember the exact numbers, so I might have write down the actual values.
If anyone has anything to add to this, or needs more clarification please let me know, I am happy to help.
Thanks,
Rick
Old 02-20-12, 12:05 PM
WadeLovell
WadeLovell's Avatar
Great write-up! Tks.
Old 12-26-15, 06:40 PM
Tory4
Tory4's Avatar
I know I am bringing back a thread from the dead but just want to note. Unless I am missing something...
The resistances on the is300 cruise stalk (both the 01-03 and the 04-05) are not correct. I tried both stalks and they both use the same resistances. The Resume (+) is close to that of the Set (-) and Set (-) is close to that of Cancel. There is no close resistance for the Resume (+) on the stalk. Some may find this useful. The only way to truly get this stalk to work is to pull the resistors out of the cruise stalk and put the correct ones in the right place. I had trouble finding resistors small enough to fit in the is300 stalk so I did some fabricating to make the stock SC400 stalk fit in the is300 wheel with no issues.
The reason I did this mod and didn't leave it the way it was (just having set and cancel) is this is a play car for my fiancé and she drives it on the street sometimes. She likes the cruise and would find it frustrating not being able to use it correctly.
1997Soarer
IS - 1st Gen (2001-2005)
08-02-16 09:28 PM
LMAOMAO
SC400 / 300 Classifieds
13
09-03-12 02:00 PM
Dr. Yellow
02-11-08 05:18 PM
xcelr8
01-18-08 04:25 PM
55charlie
15
01-12-08 11:51 PM
Quick Reply: IS300 Steering Wheel W/ Working Cruise in my SC3
