got a question and doesnt require the search button
i dont know ill switch it to the power position just be cruising along and then ill just smash the pedal down to the floor and a second later it roars to life and fish tails the only mods known to me on the car is the 12volt fuel pump mod and resenators removed and it has true duals and still coming out of the stock mufflers other than that i dont know of anything else and the alignment is fine and tires have plenty of tread i posted this cause i was curious myself as to how a basic stock car could acheive this now it doenst happen everytime i try to do it kinda when it wants to I also posted this cause i was worried maybe something was going wrong and hence would give the car the ability to do this
First thing to do is check the obvious, your tires. check for even wear and obviously proper tire pressure. Next i would check into your alignment, as well as all your rear suspension parts i.e bushings, traction links etc
i run my air pressures at 40 psi which is 8 more then recommended, busings are needing to be replaced with the mileage thats on the car and from some of the sounds i hear I know it needs them ALL replaced also the rear struts are weak
You guys are funny... Don't worry bro, it'll get better... I think people just didn't quite understand what were you implying... I myself was confused so I didn't comment in the beginning... But yeah, tires pressure also contributes, and might as well tone it down, cause 40 is a lot, and it may cause blow out... But other than that, it might be bushings, the rear is notoriously hard to deal with because its a 5 link suspension, alignment can also controbute to this, but other than the suspension parts, the engine looses a lot of HP from the tranny being a 4 speed and an auto, so yeah, people would really say it's impossible from a stock 1UZ...
so did some thinking do you think with the sudden power transfer coming down the driveline and with the weak bushings and struts whats happening is the wheels actually bounce from the torque thrust and hence why i fish tail because they actually lose contact for that split second
My guess is the tires, i bet there is enough wear to get the rear to track! So when you mash the throttle you change the weight distribution, which is when you feel the tracking or "fish tail feeling". Im sorry but there is no way a stock, auto 1uz will transfer enough power to cause traction loss on the rear wheels.
Or your driveline is loose somewhere and is shifting under load...
I can't do this with my vvt-i 1uz. From a stop, yeah no problem, and If I gun it while turning the tires break loose easily, but 60mph in a straight line? I wish. Something must be up.
well i got under the car and found that the bushings on the diff are about ate out so i know what im doing today.... anyways im calling it quits on this subject matter and just going to focus on bringing her up to date on all of her bushings and other suspension parts but im going to be out looking for another climate control to play with today and another dash cluster
