Amp. remote turn on:
I am installing a new amp. in the trunk of my sc 400, where would i connect the remote turn on? I don't have any stock stereo equipment in the car. I need help finding a wire to connect.
Thanks,
GT
Thanks,
GT
It does, I want to connect the amp remote with a wire in the trunk area. I was trying not to have to connect the wire to my head unit remote. If I must, I will use the head unit remote.
Thanks,
GT
Thanks,
GT
Chicago Lexus Club Moderator
Originally posted by gthenry1
Thanks,
I will try these. Something should work.
GT
Thanks,
GT
There are many options. You can also run a T-split off the "Accesory" (ignition) wire. that way the amp turns on when the car does (fyi this is the same wire that turns on the head unit). The remote is just a continuation curcuit off the headunit of the accesory power line. with a diode to bypass if it is not hooked up.
Chris
Thanks Everyone,
I finally got the amp wired. I connected the remote wire to one of the wires that were connected to the factory amp.
Once everything was wired ok I then noticed that my air bag light came one. What should I do now?
GT
GT
Thanks Everyone,
GT
Thanks Everyone,
GT
The wire was already through the firewall. I had replaced my instrument panel a few days ago and everything went fine.(no air-bag lite) I rewired the car and installed the amp 2 days ago, then today, all I did was disconnect the battery and connected the remote wire, the I re-connected the battery and there was the air bag sensor lite.
Chris
MistaWong
04-15-16 11:18 AM
Sheehan1p
01-15-10 03:42 PM
