SC- 1st Gen (1992-2000)
lowbeam headlight out
Old 03-21-12, 04:00 PM
DJVe
DJVe's Avatar
Default lowbeam headlight out
so when turning on the headlights yesterday, i noticed my passenger side low beam bulb was out. to confirm it was the bulb, i switched the bulb over from the driver side to the passenger side and it worked. but then when i put the bulb back in the driver side, it was out too!
i checked the fuses, not just the headlight ones, but all the fuses in the fuse box under the hood, none of them were out. the bulbs do not look burnt out and are fairly new stock philips bulbs. is it potentially the connection to the bulbs that's causing this? if so how can i test it/ fix it? any help would be greatly appreciated.
Old 03-21-12, 04:07 PM
MooJohn
MooJohn's Avatar
The connector can't blow the bulb. My guess is you got a fingerprint on the bulb's glass or the bulb just happened to fail at that time.
Put a new set in and see what happens.
Old 03-21-12, 06:14 PM
g4ebguy90
g4ebguy90's Avatar
Hes saying that he switched it to the other side and it worked, but he put it back and didn't again. I believe.
Old 03-21-12, 06:16 PM
yell0w
yell0w's Avatar
even though your fuses look good just try new ones. My buddie had the same issue before and it was just the fuse.
Old 03-21-12, 06:32 PM
g4ebguy90
g4ebguy90's Avatar
Connecters can corrode, and I have also heard of wires corroding on the inside. Hopefully it is not that in depth of a fix.
Old 03-21-12, 06:52 PM
DJVe
DJVe's Avatar
ok i will be trying both other bulbs and new fuses, thanks for the tip.
Old 03-21-12, 06:53 PM
DJVe
DJVe's Avatar
so connectors is a pretty deep fix huh? dang. ok hopefully the other solutions work!
Old 03-21-12, 08:11 PM
g4ebguy90
g4ebguy90's Avatar
If its just a connecter then you could just go to a junkyard cut on and then re-wire yours. I have only of complete corroded wires seldomly.
mike6873
ES - 5th Gen (2007-2012)
04-20-21 12:00 PM
allstock
04-21-14 11:47 PM
Mrd916
IS F (2008-2014)
01-19-13 08:12 AM
ThermonMer
11-12-11 01:29 PM
HustleHard
12-25-05 01:32 PM
Quick Reply: lowbeam headlight out
