steering wheel tilt
so my steering wheel tilt works up and down but not in and out on my 98 sc300. ive seen the diy on steering wheel tilt but it only seems to address the up and down feature. anyone else encounter the same problem? any solutions. thanks
I'm dealing with the same issue right now personally, it works sometimes (but most of the time not) so I've got to tear down the center again to diagnose that part. If it was anything like my Up/Down motor it's either over torqued or dead motor. Mine when it works makes a slight woosh noise and barely goes in/out.
Make sure u have the right model selected. I had the same problem and ended up being a cheap and easy fix....broke about 6months ago and I haven't had any problems since.
im still not sure if the in and out feature is related to the same motor or if it's different
1JZ Single SC400
If the plastic gear is messed up, order another one from the dealer and put in a thick washer behind it first. This will help the plastic gear align with the motor and grooves better. make sure to apply better grease. Mo grease the better and the quieter it will be, GL!
On the in and out feature, not too much covered here on that particular item. I would check the motor under the steering and clean the parts with some carb cleaner and see if that helps.
