SC- 1st Gen (1992-2000)
can toyota part will fit lexus sc300
Old 04-08-12, 09:02 PM
kevinsc300
kevinsc300's Avatar
Default can toyota part will fit lexus sc300
Hello everyone,
I have a 1995 lexus sc300, I need to replace the alternator, radiator fan blade and I would like to know if there is any toyota car part will fit to lexus sc300?
please help me out.
Old 04-08-12, 09:17 PM
MIGS
MIGS's Avatar
no. nothing toyota will fit on a lexus.
if you notice under the hood of SC300, nowhere does it say toyota.
Old 04-08-12, 10:49 PM
2slow2care
2slow2care's Avatar
Compatible Supra parts for the SC300/400
Supra wheels will fit the SC coupe perfectly; However, the offset is slightly less in Supra wheels (Lexus +50mm, Supra +38mm). This is not a substantial enough difference to create steering issues, but the wheels will look like they are tucked in by a little under an inch. This difference can be remedied with H&R 15mm spacers. Supra TT wheels are 17x8F and 17x9.5R, while the Supra NA wheels are 16x7.5. Both sizes are offered in chrome, polished aluminum, and silver finishes.
Any OEM and aftermarket suspension designed for the MKIV Toyota Supra will also work with the SC coupe. This includes all Supra coilover packages. Ony thing you must consider when shopping for Supra lowering spring packages: you must swap the entire strut-spring assembly from the Supra rear end, not just the springs. Meaning if you purchase Eibach Supra Prokits, you must also purchase Supra-compatible strut shocks, because the rear strut perch on the Supra sets lower than the rear strut perch on the SC. If you attempt a Lexus shock with a Supra spring, you will actually lift the rear end of the car higher than stock. The front struts are the same on both cars however. You have the option of buying the OEM Supra shocks (cheapest), or aftermarket Tokico, KYB, etc shocks. It is recommended that you replace all four shocks together for uniformity, instead of just the rears if you go this route. Supra NA and TT shocks will fit the SC300 and SC400 fine. You do not have to worry about these compatibility issues when you buy Supra coilovers.
Supra OEM front and rear sway bars will fit the SC coupes provided that you use the Supra sub-frame mounts - (info provided by Dave Martel). The stock Lexus sway bars have completely different sub-frames.
Supra OEM control arms can be interchanged with SC control arms.
Supra braking systems will fit the SC coupes as a direct bolt-on provided that you use 17x8-inch wheels or larger with the proper offset. These are very large brake calipers, which require specific offsets to clear. You want at least 2 mm or more clearance between the calipers and the backside of the wheel spokes. It is not recommended that you compensate by shaving the brake caliper, and definitely not the wheel spokes. Supra braking systems will not fit on the SC300 or SC400 with stock Lexus wheels mounted.
The Supra TT Torsen 3.76:1 Limited-slip differential bolts up to the SC300/400 rear axle as well.
The TRD performance panel air filter made for the Toyota 4Runner and Supra (Part #: 00602-17801-002) will work with the SC coupes. These TRD filters nearly double the air flow capabilities of the stock intake system when combined with the Peter Scott BFI intake.
The front seats from a Supra directly bolt-on to the SC although you lose powered lumbar adjustment. 93-95 Supra seats are different from 96-98 Supra seats. Incidentally, you can also use stock Honda S2000 seats in the Supra and SC coupe.
Old 04-09-12, 05:28 AM
MDSC
MDSC's Avatar
every box you got from the dealer has toyota stamped on it, engine wise everything from a supra fits sc...but who didnt know this aready who cares. All the parts are made by toyota. Supra tt lower control arms are the only part that is cheaper vs Lexus Sc specific that i have found so far. Everything else is same part # same price.
Old 04-09-12, 05:31 AM
lexdud
lexdud's Avatar
Hilarious ...
I was going to say something a bit more "to the point" but your reply says it better.
Old 04-09-12, 11:47 AM
kevinsc300
kevinsc300's Avatar
Thank you so much for these informations, they are really helpful.
O. L. T.
09-16-14 11:24 PM
ChrisH
Suspension and Brakes
06-05-12 02:12 PM
lexsc492
Performance & Maintenance
10-04-07 10:30 AM
GotToyota?
Wheels, Tires & Brakes Forum
03-05-07 08:11 AM
Last5Spd
09-29-05 01:00 PM
Quick Reply: can toyota part will fit lexus sc300
