is this normal??
Both SC's I have owned there temps stayed at different positions, your seems a tad bit high. But again nothing to worry about as long as it doesnt go above that, I would also check your cap etc. You have to pressure test the cap, most auto parts stores s hould have it.
Update so I changed the rad cap and it stills goses up where the pic shows,put then goses down a lil it goses back and forth but dosent go over that what could it be,its a new raditor,new raditor cap, new water pump ,new theromsta what is it should I be worried,i hate driving just staring at it..
Sounds like an air bubble in the cooling system especially if you just did a thermostat recently. It's really easy to think its full of coolant when its not quite. Buy a funnel with a radiator cap attachment and let it run for about 20 mins with the heat on til all the bubbles are done coming out.
i replaced the coolant temp sensor with an autozone unit when i thought it was bad it reads alil higher then what an oem one does, the one that was in the car was dead middle then it would peg H cuz i forgot a ground and thought it was the sensor so i replaced it and now its slightly under the line where yours sit right now
That seems a little high for me. What are your outside temps in Florida these days? What kind of coolant are you using? You could have air in the system, a clutch fan going bad, water pump issue, radiator leak, bad thermostat, or worse bad HG....do a pressure test and find out.
That's considered normal, although it's a bit on the high side. I live in Arizona and I have never seen my temperature needle go up that high. If I saw mine go up that high, I would assume that the coolant is low or thermostat is not opening all the way.
Taka
08-31-03 11:07 AM
