Wide body wheel and tire fitment???
Does anyone know what width of tire i can use on a Vertex ridge widebody? i searched it and all i got was stock body wheel fitment. Im hoping at least 10" wide rear tires are possible with rear fitment.
on the ridge kit I could fit a 18x13.5 with a 5 off set and still be fine and still have room to go more inward toward the coilover.
I run 19x11.5 -30 in the back of my car now with the ridge kit.
If your having to save up for the ridge kit forget the kit since you probably wont be able to afford the wheels for a while either.
002j (01-21-21)
Im not set 100% on the ridge kit itself but from what i read i thought stock bodies could only do 245 width tire. every tire fitment post i seen they had wide rims but stretched 245s to fit the rim. good to know i can fit 315 if i wanted. Really all I want is a 275-285 width tire. I just had in my mind that i needed to go wide body to get wider then 245 width tires.
guys also need tot take into consideration camber to. You want mad hellaflush look or BEEF man sized tires and the correct suspension geometry. That will make a huge difference as 1* of camber was about 5mm of offset if I remember correctly
2013gs350
RC F (2015-present)
13
06-17-16 01:57 PM
Insedanity
06-16-16 10:27 AM
