LED install on SC300 Cluster experience.
#31
how about making these to fit the cluster? http://video.google.com/videoplay?do...47339061120203
#33
I bought the same LED's as you suggested and they are much smaller than the bulb "housing". They practically rattle inside so I took them out. How did you get yours to stay inside the bulb housing tightly?
SuperbrightLED's doesn't take returns so I'm out $30 bucks
Should have gone with my gut and just sent this cluster away to Lextech.
#35
1JZ Single SC400
I also went with suoerbrightleds. I was overall impressed with the quality of bulbs but i also have hot spots. The same positions as yours. Overall it looks good and i can live with mine.
#43
If you guys knew how to solder in resisters you could use these
http://www.superbrightleds.com/morei...llilumens/341/
I just put these in my cousins cluster and guess what...... no spots
#45
1JZ Single SC400
I used the reflective tape on the inside of mine. The kind people used on AC duct work but without the lettering. I had to cut several small pieces. The results were alot better, I also. It was not perfect, but it was alot better and well worth the effort. Just peel and stick on the white plastic. Good luck.
