SC- 1st Gen (1992-2000)
Mirrors and Lock Problem
Old 04-19-12, 08:37 AM
Phamtom
Phamtom's Avatar
Default Mirrors and Lock Problem
Tried searching and I did come up with a few helpful threads but nothing that solved my problem. I've checked the Mirror, Door and PWR fuses and replaced them all to no avail. I also tried changing out the black relay above the kick panel fuse box. Hopefully OLT or someone knowledgable with electric stuff can chime in...
I need help with power locks/mirrors: my remote will unlock/lock all of my doors but when I start driving, the auto lock will only lock the passenger door. The manual unlock/lock button only works with the passenger lock also. For some reason it only works with the passenger door. But when I use my keyless entry, it can both lock AND unlock. So I have no clue what's going on there.... It works but at the same time, doesn't work with the button or with the "auto safety lock" when I start driving.
Possibly a related issue, my power folding and adjusting mirrors won't work. I'm pretty sure they stopped working right when my lock started acting up. They definitely worked before. No idea what could be causing the issue for this one. I checked both the blue and white plugs by the kick panel fuse box.
I hope there's something else I haven't checked cause I really don't want to rewire my door.
Thanks!
Old 04-20-12, 07:26 AM
SpadedOne
SpadedOne's Avatar
I have pretty much the same problem. Power mirrors dont work and passenger side lock doesn't work with the power lock switch. Haven't checked any fuses yet, but would like to know if anyone else had this problem and how it was fixed.
Old 04-20-12, 08:11 AM
BAD954BOI
BAD954BOI's Avatar
I had that problem it costed me alit toe short of 5 bills to fix, it's the wiring in the driver door that's jacked up.
smksc430
06-09-15 02:24 PM
mr2jspec94
07-28-10 04:40 PM
ALLWiTE2JZ
06-28-10 08:36 AM
eroc75
05-24-08 06:59 PM
gttosc
04-26-05 09:51 AM
Quick Reply: Mirrors and Lock Problem
