My rear brake light on my spoiler doesent work....
is there anyway to check to see if there is a wire loose...
i think my detail guy might have bumped it..
thanks in advance...
I had the same problem with my car. There is a wire that runs down the right hinge of the trunk into the passenger compartment. There should be a taped wiring harness near the trunk hinge(mine was getting pinched when I shut the trunk). Turns out the wire broke after years of opening and closing the trunk. Give that a check....I think the wire was green.
hmm i still cant seen to find that wire..there is a black tube coming from the trunk hinge is it in there?....or is it near that yellow wire on the opposite side?....
but the thing still doesnet work it came on a few times but im not sure what is wrong with it...and more ideas?
TIA
TIA
What do you mean it came on a few times? A few times after you connected the wire?
If so, maybe try changing the bulbs...very cheap....then if its still doing it you must have something coming loose wirewise in that area.
very interesting!
Kruso
04-06-09 08:43 PM
