SC- 1st Gen (1992-2000)
green light
Old 11-04-02, 10:07 PM
TGRich
TGRich's Avatar
Default green light
Can anyone get me a part number and price for the green interior light located underneath the dash (to the left of your legs where you would sit)?
Thanks
Tim
Old 11-05-02, 01:15 AM
jimmit
jimmit's Avatar
I need it too. Mine burned out a while ago.
Old 11-05-02, 01:44 AM
siniquezu
siniquezu's Avatar
If its on the door and turns on when you open the door, it should be a regular wedge bulb.
Old 11-05-02, 12:49 PM
ACleanSC4
ACleanSC4's Avatar
No, it's not the the same wedge bulb Siniquezu...
It's actually smaller and has a greenish sleeve covering it I think. I removed the sleeve and it looked a bit better.
Has anyone ever replaced the light behind the "hour, minute, reset" area on the console?
Old 11-05-02, 09:01 PM
rushgator
rushgator's Avatar
That bulb number is listed in the owners manual.
Never replaced that console bulb, but I am wondering this: is the word "security" on the bottom rt of the instrument cluster suppoed to lite up? All the script on the trip computer & etc buttons do, and it seems like the security script should.
Old 11-06-02, 02:07 AM
siniquezu
siniquezu's Avatar
Unhappy
Which bulb are you guys talking about? I looked in the user manual but don't see anything about a green bulb.
Old 11-06-02, 02:51 AM
mjr24
mjr24's Avatar
Talking I have answers!
OK, I never had to replace the green light under the dash there, but if it has a green sleeve, then it can be ordered from the dealer. Take it to the dealer and they can look it up, prob. $5-10.....and reuse your green sleeve from the old bulb.
Tony, I did replace that light. At first I took it to my local dealer and they looked on the computer and said the whole switch had to be ordered, the bulb couldnt be ordered by itself. I opened the switch and the bulb came out and I couldnt believe it couldnt be ordered....because it was made to be taken out (not like it was soldered in). I emailed my friends in Glendale, CA, at BMA Auto Parts and sent the bulb there. They gave it to Glendale Lexus who found a bulb just like it (I assume the bulb is used for other things). It cost me like $6.00.
The security red light should light up, the actual word itself should not.
Old 11-06-02, 02:53 AM
mjr24
mjr24's Avatar
Oh and I looked in my owners manual, that green bulb is the footwell bulb.....1.2 watts...but it doesnt list a part number.
Old 11-06-02, 03:50 AM
lex400sc
lex400sc's Avatar
What is this mysterious green bulb you guys speak of in the footwell? I don't have any green lights in my car! :eek:
Old 11-06-02, 09:31 AM
mjr24
mjr24's Avatar
OK, if you open your door....on the drivers side there will be the obvious light on the door itself.
Theres another light....its further down from like the remote control on/off switch. Feel down there...you will feel the clear plastic cover for it. Theres only a footwell light on the driver side though.
Old 11-06-02, 12:14 PM
Taka
Taka's Avatar
I guess mine is already burnt out , never noticed the green light before. I'll check tonight.
Old 11-06-02, 03:59 PM
rushgator
rushgator's Avatar
Talking
Thanks! Just what I wanted to hear. Much easier than taking apart the dash to find that out
Old 11-07-02, 12:55 AM
Taka
Taka's Avatar
nope, couldn't find it.
Old 11-07-02, 01:07 AM
siniquezu
siniquezu's Avatar
me neither....
Old 11-07-02, 01:32 AM
ChrisSC300
ChrisSC300's Avatar
Its pretty simple to find. Its just a bit further behind the end of the steering wheel column. Its a triangle shape. And its very obvious to see, just open your door at night and sit in your car....if your legs are green, its working. Its the same color as the green ring around the ignition.
Quick Reply: green light
