SC- 1st Gen (1992-2000)
remove fog lights 99 sc300
Old 05-11-12, 07:25 AM
bighead222
bighead222's Avatar
Default remove fog lights 99 sc300
Like the title says how do I remove the fog lights from a 99 sc300??
Old 05-11-12, 07:42 AM
horent135
horent135's Avatar
If I remember correctly, it two screws on the side and one screw on top.
Old 05-11-12, 08:59 AM
Tabaka
Tabaka's Avatar
Three bolts, that's it. I believe they are 8mm. Make sure to unplug the wire harness before yanking them out. I believe you have to unscrew the fender liner and remove the engine undercover to access the lights. It will probably take 30 minutes per side.
Old 05-11-12, 11:23 AM
mak89
mak89's Avatar
Using it for the supra?
Old 05-11-12, 02:23 PM
bighead222
bighead222's Avatar
Naw just got sum yellow fogs
Old 05-14-12, 04:28 PM
cameratoaa
cameratoaa's Avatar
I was able to get mine out by sticking my entire arm into the hole in the bumper next to each fog light and using a mini philips screwdriver, but you need small hands.
Took about 10 minutes per side, 8 of which were finding the screws.
tomknez
CT 200h Model (2011-2017)
07-12-19 01:28 PM
SlvrBulit
01-15-12 06:50 AM
johnnybmw1
12-11-08 03:58 PM
lieu510
IS - 1st Gen (2001-2005)
01-04-05 10:12 PM
howiedoit
08-07-01 01:32 PM
Quick Reply: remove fog lights 99 sc300
